Re-license ArcGIS Enterprise using Chef
838
11-20-2018 08:12 AM
DamienRobinson2
I was wondering if anyone has used Chef to re-license ArcGIS Enterprise? The github has plenty of info on building ArcGIS Enterprise from scratch, but i can't seem to much info on issuing a new license to an existing ArcGIS Enterprise (when renewal time comes).   chef cookbooks chef chef scripts
BillBott
Little late on this one, but FWIW don't see this as a stand-alone Chef script. Updating the license file is pretty straightforward though, replace the "keycodes" file in the license directory with the updated license file. The harder part is updating all the GDBs with the new SDE license. This part done through SQL or existing GDB connections
DamienRobinson2
Thanks Bill!
I have decided to go with a serverless solution using a combination of remote PowerShell (dropping the license files locally and calling the command line tools for Portal/Server/Data Store licensing) and arcpy (UpdateEnterpriseGeodatabaseLicense for SDE license).
BillBott
Sounds like plan Damien. One catch, there is a bug in Pro 2.1-2.3 that won’t let you create new GDB connection for an unlicensed server. Since UpdateEnterpriseGeodatabaseLicense  requires an SDE file this becomes a bit of an issue if the server is in an unlicensed state. I submitted an issue to support.
Workarounds are to update the database directly with the new auth key or create the SDE connection file in ArcMap.
ArcMap prompts the user to add the new license when creating a new connection to the database and it detects the server is unlicensed.
Good luck!
DamienRobinson2
Thanks for the heads up Bill Bott
