AUTO-UPDATING STREAMING IN COLLECTOR FOR ARCGIS
501
11-19-2018 02:12 AM
Elijah
Occasional Contributor II
While I stream along lines in the field with collector, I need to have such lines viewed from the office by my colleagues AS I STREAM. Somehow, the lines are only visible when I manually submit/  update. Is there any way to have the lines auto-update/submit as I stream, so that it become visible at the other end as the layer updates??
Thanks in advance.
DerekLaw
Esri Esteemed Contributor
Hi Andy,
> ... the lines are only visible when I manually submit/update
This is expected behavior. The feature you're currently adding in Collector will only be visible in the web map AFTER it's been submitted.
Unfortunately, no and this is by design. The feature is only updated in the "back end" after you explicitly submit the edit. It does not update as you are making edits to the feature.
Hope this helps,
DerekLaw
Hi Andy,
Hope this helps,
Elijah
Hi Derek,
Thanks for your answers. I do appreciate it. However, don't you think such
an option may be beneficial especially when streaming a line? Submitting at
each segment and restarting to collect is a little more manual than one may
wish to do. Just thinks it could be added as an option.
DerekLaw
Hi Andy,
Please submit an enhancement request on the ArcGIS Ideas site for Collector for ArcGIS.
