AnsweredAssumed Answered
[JSAPI 4.9 vs 4.8][Feature Layer] Related Fields in Popup is not Showing
Question asked by Justdoit011 on Nov 16, 2018
I have a ArcGIS portal item with a feature layer. It has predefined popup template with a related field "relationships/0/Point_Count_COMMON".
I was trying to display this portal item using JSAPI v4.9. However, the "Count of Points COMMON" field in popup window is always empty when I opened the popup.
When inspected using Chrome F12 tool, I can see the HTTP Request for related layer info was canceled. Maybe it was the cause of the empty related field.
I also tested the same program with JSAPI v4.8. Everything works fine.
The source code is very simple:
var map = new WebMap({
    portalItem: { // autocasts as new PortalItem()
var view = new MapView({
    map: map,
    container: "viewDiv"
Below is a running example:
https://codepen.io/anon/pen/mQMEza
Outcomes
