I want to create a Story Map Tour using my Survey123 results. Map Tour is ideal as it automatically makes the photos visible. The text window appears to limit you to two fields of your choose as you are using the Map Tour Builder. Is there a simple way, without messing with the code, to add an extra field?
That's not possible, and I think it might be hard to do even with customizing the code. It is better to try and concatenate multiple fields into the two fields that Map Tour expects (one for the place name, one for the place caption). For example, you could concatenate multiple data fields and include HTML formatting too to generate the field that the Map Tour's caption will display.
Rupert
