arcgis.apps Suvery123 is not an attribute
476
11-16-2018 11:13 AM
FredKellner2
After reading this article about the new Python API 1.5.1 release. I was most interested in checking out the Survey123 module.
I am using the API in Anaconda rather than through an installation of ArcGIS Pro.
When I use the command print(arcgis.__version__) i get : 1.5.1
However when I try to use the module I get the error: module 'arcgis.apps' has no attribute 'survery123'
I am wondering if anyone else is able to successfully get the Suvery123 module to work?
John Yaist
by Anonymous User
Not applicable
Hi Fred,
I think you might have a typo it in your import (an extra "r"). Try "from arcgis.apps import survey123"
FredKellner2
Hi Aaron, Thanks for point this out!
JohnYaist1
Thanks for pointing the is out, Kellner .
For now try this code to import survey123 and make an instance of the SurveyManager:
from arcgis.apps.survey123._survey import SurveyManager, Survey‍
survey_mgr = SurveyManager(gis=<your_gis>)
