I cannot add graph to layout as it seen on pop-up graph view window.
1141
11-14-2018 11:24 AM
BilgeKose1
I'm trying to add a graph to the layout in ArcMap version 10.6.1. However, it when I right-click on the graph and select "add to layout" it shows up with a black background and does not appear on my layout "as it is" on the pop-up window. The same thing happens when I try to add the graph from the graph manager.
I checked the properties and I restarted the pc but nope, it didn't work out. I also tried the same data with another pc but worked perfectly on the other pc. I can't figure out what's happening.
Can you help me with this? I'm also uploading a photo how the graph appears on the layout view. Thanks a lot!
JAMIESOMMA
New Contributor III
Same issue. Using ArcMap version 10.6.
Christopheraime
Same issue with arcmap 10.8
