WebGL (PBF Format) in ArcGIS Server 10.6.1
4151
9
11-12-2018 01:36 PM
philippenn
Have ArcGIS Server Enterprise 10.6.1 instance with a FeatureService with a single point layer. If I go to http://<myarcgisserverurl>/<myservice>/FeatureServer/0/query I do not see PBF as a format in the drop-down.Nor can I jigger the URL querystring with f=PBF (Format not supported). Is there something I need to do to enable the PBF format? Can't seem to find documentation on this -- I know it was previously only in ArcGIS Online but thought it was a 10.6.1 capability.
ToddAtkins
Just a guess, but I think you may have to pass quantizationParameters to the endpoint. Query (Feature Service/Layer)—ArcGIS REST API: Services Directory | ArcGIS for Developers
philippenn
I don't think so...my FeatureService Layer is a point layer and I _think_ that supportsCoordinateQuantization  is only for polylines/polygons. At least, I don't see where to set that.
ESRI, I can't be the only person wanting to serve up lots of features using 10.6.1 to a WebGL client and not using AGOL/Portal. Is a small blog entry guiding us through this a possibility if it is more than one setting? Otherwise, what is the setting I'm missing?
thanks in advance,
Phil
ToddAtkins
Our point layer says supportsCoordinateQuantization: true but we are also using AGOL. I haven't spun up a 10.6.1  server so no idea if it operates any differently (one would hope not though, lol).
philippenn
Checked and our point layer also says supportsCoordinateQuantization.
Also rejigged the URL to map to our own service...but no die, just get Format Not Supported
Supported Query Formats: JSON, AMF, geoJSON
http://<server>/arcgis/rest/services/<service>/FeatureServer/0/query?f=pbf&geometry=%7B%22spatialReference%22%3A%7B%22latestWkid%22%3A3857%2C%22wkid%22%3A102100%7D%2C%22xmin%22%3A-8228293.22084349%2C%22ymin%22%3A4960457.387596488%2C%22xmax%22%3A-8225847.2359383665%2C%22ymax%22%3A4962903.372501614%7D&maxRecordCountFactor=3&outFields=*&outSR=102100&quantizationParameters=%7B%22extent%22%3A%7B%22spatialReference%22%3A%7B%22latestWkid%22%3A3857%2C%22wkid%22%3A102100%7D%2C%22xmin%22%3A-8228293.22084349%2C%22ymin%22%3A4960457.387596488%2C%22xmax%22%3A-8218509.281222992%2C%22ymax%22%3A4970241.327216988%7D%2C%22mode%22%3A%22view%22%2C%22originPosition%22%3A%22upperLeft%22%2C%22tolerance%22%3A19.10925707128908%7D&resultType=tile&returnExceededLimitFeatures=false&spatialRel=esriSpatialRelIntersects&where=objectid+%3C+100&geometryType=esriGeometryEnvelope&inSR=102100
ShaharBukra
New Contributor III
Just came across this yesterday when try to load large polygon feature layer (200K),
Try to find the solution by myself,
hoped i missed some checkbox, but couldn't find anything...
Jeremy Bartley
Derek Law
Noah Sager
HectorMendia
PBL Format is not available in ArcGIS Server 10.6.1
It will available for 10.7
RichGwozdz
New Contributor III
How can the PBF responses be decoded?
HectorMendia
Is loaded like a JSON
featureLayer = new FeatureLayer({ url: .... }); // response are in PBF format
console.log(this.featureLayer); // <-- JSON
by Anonymous User
Not applicable
is feature service PBF a layer that can support popups and query? In other words, will it finally allow for fast layers that can scale to heavy load, like the Hosted Feature Layers do currently on AGOL?  Will this kind of layer work in IE11?
