Is it possible to clip a map based on a grid? I want to specify one UTM zone and clip the region, but I can't figure out how to either convert the grid to a feature layer to apply a clip or clip the map extent inside the zone.
I believe ArcMap has a similar tool, but I'm not sure if Pro does.
Jonah
Make things easier.
A quick way would be to specify the utm zone in decimal degrees first.
Why? I doubt you need the whole UTM zone, just the latitudinal belt that applies to your study area. If that is the case, make a feature class that encompasses your zone.
For instance, UTM zone 18 N(orth) is bounded by -78. to -72 degrees longitude. Now my area is between 42 and 48 degrees latitude.
In either case, you will have you 'UTM' zone defined with their appropriate coordinates (note, in Europe some of the zones have specific bounds that don't follow the normal way of dividing the longitudinal bands )
If you know what zone you live in Dr Google and Dr Wikipedia have some guidance
