Exporting multiple Web Feature Layers as Geodatabase
1451
11-08-2018 02:53 PM
ScottWagoner
New Contributor III
I have been working on this python script and I cannot figure out why it is not working.  I have about 15 Web Feature Layers I want to regularly export to individual geodatabases then download them using the script.  If I try to just download them it returns a 1kb zip file.  So after looking online for a solution a ran across this one:Download feature service as file geodatabase
It worked great for 1 file, but like I said, I have 15 I would like to regularly download.  so I spent some time tweaking that and come up with this code:
import time
import os
import zipfile
import arcgis.gis
from zipfile import ZipFile
# *** modify these four lines ***
outputFolder = r"OUTPUT"  # where the GDB will be extracted to
gis = arcgis.GIS("URL",
                 "USER", "PASS"# replace these with your credentials
item_id = ["ID1", "ID2", ......]
GDBname = ["MULTIPLE_NAMES"]
for i in range(len(item_id)):
    AGOLitem = gis.content.get(item_id)
    print("Exporting Hosted Feature Layer...")
    AGOLitem.export(GDBname, 'File Geodatabase', parameters=None, wait='True')
    time.sleep(10# add 10 seconds delay to allow export to complete
    search_fgb = gis.content.search(query="title:{}*".format(GDBname))  # find the newly created file geodatabase in ArcGIS online
    fgb_item_id = search_fgb[0].id
    fgb = gis.content.get(fgb_item_id)
    fgb.download(save_path=outputFolder)  # download file gdb from ArcGIS Online to your computer
    print("Zipping exported geodatabase for download...")
    '''while statement runs until a valid zipped file is created'''
    # randomly the output is a 1 KB file that is not a valid zipped file.
    # The while statement forces a valid zipped file to be created.
    zipfullpath = os.path.join(outputFolder, GDBname + ".zip"# full path to the zipped file once it is downloaded to your computer
    while zipfile.is_zipfile(zipfullpath) is False:
    zf = ZipFile(os.path.join(outputFolder, GDBname + ".zip"))
    '''deleting hosted File Geodatabase'''
    # NOTE: This will delete the temporary File Geodatabase in ArcGIS Online
    print("Deleting "+fgb.title+"("+fgb.type+")"+" from ArcGIS Online...")
    fgb.delete()
print("Done!")
  When I run this it gets to zipping exported geodatabase then it gets hung up.  In the folder it is supposed to save to, I have either a service definition or just a file with the original file name (So if the name online is "Features_for_you" but GDBname should have been "New_Features" I will get a file with the name: "Features_for_you".
Things I have tried:
  • I thought maybe I wasn't waiting long enough for the export, so I extended the sleep to 200 seconds just to test. Same result
  • I have 2 text files, one with the id and one with the GDBname.  Instead of a long list I had:
    • item_id=open("id.text").read().splitlines()
    • GDBname=open("id.text").read().splitlines()
I do have another log-in that I use.  I upload some smaller test data and ran the exact same script with only 3 Feature Layers and it worked just fine.
The only difference between the live data and the test data is the live data has a ton of information:  I believe each Feature layer has 4 - 10 layers and each individual layer has 40 -70 fields with domains all over the place.
Any reason my script isn't work properly?
spenniken
I've had to do the same thing, and had success with the following script. Hope it at least points you in the right direction.
from arcgis.gis import GIS
portal_url = r"https://www.arcgis.com/"
gis = GIS(portal_url,'username', 'password')
print("Connected to AGOL & Authenticated")
#Add the list of item IDs separated with a comma
featureService_ID = ['0bb9e555d84d4dafbb0a1c04f80e3f7b',
'fc22d7ee7dd1555eab5d7886f9381807',
'782f2c16c6555de0a2dfb7ba13f79c97',
'76e065a555dd427ea63d8646d4f53567']
download_folder = r"C:\Users\user\path"
title = 'FLBackup'
unsuccessful = 0
for i in featureService_ID:
    try:
        item = gis.content.get(i)
        exportedData = item.export(title+'_'+i,export_format="File Geodatabase")
        exportedData.download(download_folder)
        exportedData.delete()
        print(f'Downloaded {item.title} ({i}) successfully, and fgdb deleted in AGOL')
    except:
        unsuccessful += 1
        print(f'Item {item.title} ({i}) failed to export')
print(f'\n{len(featureService_ID)-unsuccessful} items were successfully downloaded to fgdbs.\nUnsuccessful: {unsuccessful}.')
