AnsweredAssumed Answered
Regressions in Report Template Export
Question asked by llin_1234 on Nov 5, 2018
Latest reply on Nov 9, 2018 by ZWang-esristaff
1) After saving a template in Manage templates the "Saved Successfully!" message box appears and does not go away. Have to load another tab then go back to the Data to clear the message.
2) Report download does not automatically start after generation when "Save result to your account" is not selected. Saving results works but it's annoying to have to go to another page to download the results.
3) Map generation is failing. Template line of "${EncroachmentLoc | size:300:0}" throws an error:
Job ID
24027159b4e94382b89461475bdee8b5
Status
Failed
Message
Failed to print map for ${EncroachmentLoc|size:300:0}.
Removing the line lets the report generate.
4) In a different survey report template that worked last week:
Job ID
9697e5d395fb49858d2cd09ff88d67f8
Status
Failed
Message
Error occurred when checking the report template. Failed to parse "${ReportDate|format: ’MM/DD/YYYY’}"Field "${ReportDate}" does not exist or cannot be found in current parsing scope.
Outcomes
