Parcel Fabric: Error reading OID from table.
833
11-05-2018 04:15 PM
SamuelPerez1
New Contributor III
Today, I was doing some editing in our fabric, and after completing these edits and saving them, I began receiving drawing errors related to reading OID from table.  I went ahead and closed my mxd and restarted my machine to see if this might resolve the issue. After doing this, and upon opening the mentioned mxd, I continue to receive the same error prompt (see attached screenshot). I'm rather confused by what might have caused this error and how to solve it.
anna_garrett
Occasional Contributor III
that last line of the message might be what's causing it. are you on a network? because you might have lost a connection needed for that license to be read
SamuelPerez1
New Contributor III
Hi Anna,
Thank you for the reply. I am not on a network, nor do I currently use tracking analyst.
anna_garrett
that's pretty nuts. is all your data intact? because i'd just try to recreate the MXD from scratch to get around that.
SamuelPerez1
New Contributor III
My data does seem to be corrupt (only a handful of parcels displaying geometry, yet all parcels appear in the table). I just went ahead and copied a previous version from file explorer into a new location, with which I will begin using as my primary copy of the fabric. Luckily, I did not lose to many edits.
