Zonal Histogram Not Producing a File
821
11-02-2018 07:12 AM
DaveNuhn
New Contributor III
I have been using the Zonal Histogram tool recently but, It just decided to not produce a file. It is a very small amount of data I am working with and computes within seconds. I receive the message that the process is completed but no file is created. Any idea what could cause this issue, I have tried restarting everything and have no luck. I attached a screen shot of the window confirming the process being completed.
DanPatterson_Retired
try adding a *.dbf file extension otherwise it produces an 'info' table
Zonal Histogram—Help | ArcGIS Desktop
and if info tables are anything like esri  grid tables, they hate spaces in paths and files that begin with numbers... like I am seeing in your table of contents.  So they may exist, but you might have to open them manually
DaveNuhn
New Contributor III
Dan, thanks for the response. Adding .dbf totally worked, much appreciated.
