From SDE 10.6.1 on SQL 2014 ENT, I have some ghost replicas left over from a years ago TS case. The feature services that spawned them are long gone. How to remove them?
SELECT
ITEMS.Definition .value( '(/GPSyncReplica/ID)[1]', 'nvarchar(max)') AS "ID" ,
ITEMS.Definition .value( '(/GPSyncReplica/ReplicaName)[1]', 'nvarchar(max)') AS "Replica Name" ,
ITEMS.Definition .value( '(/GPSyncReplica/ReplicaID)[1]', 'nvarchar(max)') AS "Replica ID" ,
ITEMS.Definition .value( '(/GPSyncReplica/CreationDate)[1]', 'nvarchar(max)') AS "Creation Date",
ITEMS.Definition .value( '(/GPSyncReplica/GPSyncDatasets/GPSyncDataset/DatasetName)[1]', 'nvarchar(max)') AS "Dataset Name"
from
dbo.GDB_ITEMS AS ITEMS INNER JOIN dbo.GDB_ITEMTYPES AS ITEMTYPES
ON ITEMS .Type = ITEMTYPES .UUID
WHERE
ITEMTYPES. Name = 'Sync Replica';
ID Replica Name Replica ID Creation Date Dataset Name
-1 DBO.Ags_Fs A2302934-20B6-41D4-B48F-1AD84A1165E2 2014-12-17T18:32:16.27 PFMD.DBO.ESRI_TEST_MSFT
-1 DBO.Ags_Fs_1418841420633 5ECE3404-607B-4F04-A1E4-C32FDD2EAA43 2014-12-17T18:36:01.147 PFMD.DBO.ESRI_TEST_MSFT
-1 DBO.Ags_Fs_1418841988647 22D0DEA1-C164-4ADF-81C4-B1C332D607A5 2014-12-17T18:46:11.3 PFMD.DBO.ESRI_TEST_MSFT
35719 DBO.Ags_Fs_1418909174993 9FA30948-67D3-4ACB-8396-EA720ABF7544 2014-12-18T13:26:01.787 PFMD.DBO.ESRI_TEST_MSFT
-1 DBO.Ags_Fs_1419181999753 84E3E701-38EF-486E-9BAB-32D5BBDC87FC 2014-12-21T17:11:11.93 PFMD.DBO.TRAILSIGN
-1 DBO.Ags_Fs_1418841209303 C3038FE1-384E-4A2F-81B8-3752D693D41F 2014-12-17T18:33:03.64 PFMD.DBO.ESRI_TEST_MSFT
-1 DBO.Ags_Fs_1419186441983 15B5D13D-70A4-4099-84DE-3001B4639EEF 2014-12-21T18:25:30.603 PFMD.DBO.TRAILSIGN
-1 DBO.Ags_Fs_1419262786420 96CBBD68-49E3-4162-946E-2EEB7FC35154 2014-12-22T15:39:24.667 PFMD.DBO.ESRI_TEST_MSFT
40523 DBO.Ags_Fs_1420049785970 1EE77463-ED4F-431D-9395-663C85AC8EAC 2014-12-31T18:16:07.217 PFMD.DBO.ESRI_TEST_MSFT
97711 DBO.Ags_Fs_1522248749793 8BA06387-0C91-4D02-8BF3-A024293E297E 2018-03-28T14:52:20.023 PFMD.DBO.TEST_EMPTY
You can try to remove them using the Delete Version—Help | ArcGIS Desktop GP tool.
Here is a KB article: How To: Determine if there are orphaned replica system versions in the geodatabase
