Why when you choose to create a multiple choice question you cannot make it have rules. Would really like to have a multiple choice question do this. If there is a way around this please let me know.
Hi Shawn,
Can you explain a bit more about what you're trying to achieve or what rule you want to implement?
If you want based a Relevent rule on a multiple choice question, you'd use something like selected(${MCQname},'Answer1'), described in more detail here: https://community.esri.com/groups/survey123/blog/2016/05/28/the-art-of-hiding andhttps://community.esri.com/groups/survey123/blog/2017/08/30/understanding-multiple-choice-questions-...
Carmel
I am trying to set up a survey for our Solid Waste Department to use while collecting garbage everyday. Some of the questions will have more than one response to input. For example:
Set of rule for Conflicts for getting out of the cab. If selecting one answer then would have to select another answer for another question..
Hi Shawn,
That should be possible by using the Relevent column (when creating a survey, use the Advanced template which will give you all the column options):
Survey spreadsheet:
Choices spreadsheet:
More information in my original post and here: Form expressions—Survey123 for ArcGIS | ArcGIS
Carmel
