AnsweredAssumed Answered
Can I duplicate the color scheme of my old AML for a shaded elevation relief?
Question asked by huffmanp on Oct 31, 2018
Latest reply on Nov 1, 2018 by huffmanp
My agency is still using the old elevation shaded reliefs that I generated on a Sun Workstation using AML. (bottom data frame) The problem is how do I match this appearance when I get new data, or need to patch old DEM data?  ArcMap >10.3 gives you Elevation 1 and Elevation 2 and both are hideous. The closest I can find is using Pink to YellowGreen, Diverging, Dark,  set at 40% transparency on the DEM raster,  over a hillshade raster of the same DEM. (Top data frame). https://www.dropbox.com/s/jphr9f73xvl7snm/reliefcompare.PNG?dl=0
I found the old aml that produced the color scheme.  It produced a recode grid of elevation called slice based on the lookup table elev.lut, a hillshade called hill, an illumination grid called illum,  then combined them into color separates based on the color lookup table color.lut  that were later combined in a stack. Maybe if I can decode the rgb color codes in color.lut,  I could use them to symbolize a elevation reclass raster, reclassified based on the elevation breaks in the elev.lut,  then put that at 40% over a hillshade .
elev.lut
-10000 0000 :  1
0000 0250 :  2
0250 0500 :  3
0500 1000 :  4
1000 1500 :  5
1500 2000 :  6
2000 2500 :  7
2500 3000 :  8
3000 3500 :  9
3500 4000 :  10
4000 4500 :  11
4500 5000 :  12
5000 5500 :  13
5500 6000 :  14
6000 6500 :  15
6500 7000 :  16
7000 7500 :  17
7500 8000 :  18
8000 8500 :  19
8500 9000 :  20
9000 9500 :  21
9500 10000 :  22
10000 20000 : 23
color.lut
1 8 129 242
2 113 153 89
3 117 170 101
4 149 190 113
5 178 214 117
6 202 226 149
7 222 238 161
8 242 238 161
9 238 222 153
10 242 206 133
11 234 182 129
12 218 157 121
13 194 141 125
14 214 157 145
15 226 174 165
16 222 186 182
17 238 198 210
18 255 206 226
19 250 218 234
20 255 222 230
21 255 230 242
22 255 242 255
23 255 255 255
Relief.aml
&args elev_map
grid
mapex %elev_map%
/* kill slice all
/* kill hill all
/* kill red all
/* kill green all
/* kill blue all
/* kill illum all
slice = reclass(%elev_map% * 3.28089,elev.lut)
hill = hillshade(%elev_map%,345,45,#,5.0)
illum = float(hill) / 255
red = int(con(isnull(color2red(slice,color.lut,nowrap) * illum),255,(color2red(slice,color.lut,nowrap) * illum)))
green = int(con(isnull(color2green(slice,color.lut,nowrap) * illum),255,(color2green(slice,color.lut,nowrap) * illum)))
blue = int(con(isnull(color2blue(slice,color.lut,nowrap) * illum),255,(color2blue(slice,color.lut,nowrap) * illum)))
&echo &off
q
&return
Outcomes
