Survey123 Connect groups/relevance/repeat
461
10-30-2018 12:54 PM
MoniqueDulac1
I'm trying to build a logbook that would start with a yes/no question of: Is this a duplicate sampling event?  If the user says 'yes' then it would open a single text field with DUP_ already populated.  If user says 'no' the field would be blank.
Example:
User says 'no' = Site ID:
User says 'yes' = Site ID: DUP_
Any help is greatly appreciated!
GregoryLiggett
New Contributor III
I think you want a calculation in your Site ID field. Not sure I did it right, but play with it.
if(condition, a, b)
If true, returns a; otherwise, returns b.
if(selected(${duplicate}, 'yes', DUP_')
MoniqueDulac1
Thank you!  That was helpful.
In my Sit ID field I ended up putting ${DuplicateReading}='yes' in the relevant field and DUP_ in the default field.  Worked like a charm!
