AnsweredAssumed Answered
Symbolize lines in meters width from attribute.
Question asked by kelin84 on Oct 31, 2018
Hi I’m trying to see if it’s possible to symbolize a line feature, so it will get the a dashed line on each side of the line to indicate the width of the street.
I’ve tried a couple of things, but is not working like I want it to. First of all I’ve changed the map unit to cm instead of pixels. I’m not able to deactivate Scale based sizing, is grayed  out, which  probably is my biggest issue, if I could fix it, so that it won’t scale I would guess that I could use a buffer effect and connect that to the streetwidth attribute.
Is this possible some way?
Outcomes
