Critical dependency issue - Unexpected ESRI DLL files copied next to a target dll
2169
14
10-28-2018 08:45 PM
MarkMindlin
Occasional Contributor III
We have a DLLs library that references ESRI DLLs and we upgrade it from version to version constantly (10.0 -> 10.X.X -> 10.6.1). This time we have a strange behaviour: at Rebuild it copies unexpected ESRI DLL files next to a target dll.
We assume that a setting “Copy Local” in Properties of a referenced DLL is a key to understand the issue.
Why are these additional ESRI DLLs included as a reference?
What is important: We have two our dlls (solutions): first and second.
 The first  has only ESRI references.
The second has a reference to the first and ESRI references.
 The issue does not appear in the first. It appears in the second.
Any help will be greatly appreciated.
by Anonymous User
Not applicable
You can set it in the project (.csproj)
  <PropertyGroup>
    <!-- Fix the default copy local behaviour changed in VS 2015 -->
    <DoNotCopyLocalIfInGac>true</DoNotCopyLocalIfInGac>
  </PropertyGroup>
See also: Behavior change for RAR Copy Local behavior when in the GAC · Issue #24 · Microsoft/msbuild · GitHub
by Anonymous User
Not applicable
Hi Mark,
Make sure "Embed Interop Types" is set to false for Esri assemblies in their properties, otherwise you'll get a copy in the local path.
MarkMindlin
Thanks Sean,
We made sure it is. But still the same issue.
by Anonymous User
Not applicable
And copy local is false? and you still get the dll in the target path?
MarkMindlin
Yes. Please see the image attached.
MarkMindlin
by Anonymous User
Not applicable
The only way i can repro this is by setting the "reference to the first project" in the second project to copy local = true, then all the esri references get copied in. Actually this happens if any of the esri references are set to true also.
beats me. Unless anybody else chimes in here you might have to go through (developer) support.
MarkMindlin
Thanks Sean,
We have esri references set to false (all properties: "Copy Local", "Embed Interop Types" and "Specific Version") as you see on the image above. For all references across the first and the second solution. Yes, in the second, we should have the reference to the first "Copy Local" = true.
Little hope that support could help.
MarkMindlin
We reproduced it in a small demo in Visual Studio 2017. Please see attached zip at the topic "SecondProjectReference.zip" with two simple solutions.
MarkMindlin
We have compared Visual Studio 2017 and Visual Studio 2013 for the demo.
With MSBuild reports, the log output are different
(In Visual Studio, go to Tools > Options > Projects and Solutions > Build and Run. Change the "MSBuild project build output verbosity" setting to Detailed. Now clean and rebuild your project. )
For 2017
1> Dependency "ESRI.ArcGIS.Geodatabase, Version=10.6.0.0, Culture=neutral, PublicKeyToken=8fc3cc631e44ad86".
1> Resolved file path is "C:\Program Files (x86)\ArcGIS\DeveloperKit10.6\DotNet\ESRI.ArcGIS.Geodatabase.dll".
1> Reference found at search path location "C:\Program Files (x86)\ArcGIS\DeveloperKit10.6\DotNet".
1> For SearchPath "C:\Program Files (x86)\ArcGIS\DeveloperKit10.6\DotNet".
1> Considered "C:\Program Files (x86)\ArcGIS\DeveloperKit10.6\DotNet\ESRI.ArcGIS.Geodatabase.winmd", but it didn't exist.
1> Required by "ESRI.ArcGIS.ADF.Local, Version=10.6.0.0, Culture=neutral, PublicKeyToken=8fc3cc631e44ad86, processorArchitecture=MSIL".
1> Required by "BaseLibrary1".
1> Found related file "C:\Program Files (x86)\ArcGIS\DeveloperKit10.6\DotNet\ESRI.ArcGIS.Geodatabase.xml".
1> The ImageRuntimeVersion for this reference is "v4.0.30319".
For 2013
1> This reference is not "CopyLocal" because it's registered in the GAC.
