AnsweredAssumed Answered
publish hosted map image layer
Question asked by therightdirection on Oct 26, 2018
I want to publish a map from an arcgis pro projectfile with Python as map image layer in portal
so the step is to create a sddraft file and continue with a sd-file and publish.
all done and is working for feature layers
but for my map image layer with later wms capabilities python returns the message
2018-10-26 13:46:15,360 Unable to publish item.
2018-10-26 13:46:15,360 This service definition file was created for an ArcGIS Server site and must be uploaded directly to an ArcGIS Server site through ArcGIS Server Manager or ArcMap.
publishing of the sd-file in the arcgis server manager fails as well
I did some analysis of the sddraft from python and arc gis pro. they differ quit a lot and even type definitions of certain elements in the xml differ. There are a few elements which are typed as Boolean in the arcgis pro sd-draft file while they are strings in the python sd-draft file.
my code is as follow:
if createFilesWMS:
    project = loadProject(projectFileLocation)
    aprxMap = loadMap(project)
    wms_draft = aprxMap.getWebLayerSharingDraft("FEDERATED_SERVER", "MAP_IMAGE", serviceName)
    wms_draft.federatedServerUrl = arcgisServerUrl
    wms_draft.serviceName = serviceName
    wms_draft.summary = "BGT"
    wms_draft.tags = "BGT,WMS"
    wms_draft.description = "BGT als mapservice en WMS"
    wmsSDDraft = stagingFolder + "\\" + serviceName + "_wms.sddraft"
    try:
        wms_draft.exportToSDDraft(wmsSDDraft)
    except:
        print(arcpy.GetMessages())
else:
    logInformation("aanmaken sd-draft file voor mapservice/WMS wordt overgeslagen", True,False,False)
wmsSD = stagingFolder + "\\" + serviceName + "_wms.sd"
if createFilesWMS:
    logInformation("mapservice/WMS sd file maken", True,False,False)
    try:
        arcpy.StageService_server(wmsSDDraft, wmsSD)
I am curious what I do wrong here to make my map a hosted map service layer and how can I publish my map with wms-capabilities?
Outcomes
