Can I have questions in my survey that aren't stored in the feature layer?
517
10-25-2018 05:55 PM
BenjaminSperry1
I would like to have questions in my survey that affect the relevant column but are not needed in my actual data set.
For example:
I am collecting trap information, I need to record certain information when the trap is set and different information when it is collected.
If I have a question at the beginning of my survey asking the field tech if they are setting traps or collecting them then using the relevant column I can show only those fields that are important to either task; but I don't need to store whether they are setting or collecting a trap in the feature layer (in fact it avoids problems if it isn't stored).
I am using a hosted feature layer in AGOL.
I am using Survey123 Connect Version 3.0.142
Note:
  • There is a lot of information for each trap that doesn't change between setting and collecting so having two different features would be less effective.
  • The trap sites are relatively close together and they alternate between setting and collecting traps so switching between two different forms would be less effective.
ClaireProctor
HI Benjamin,
Yes, you can do exactly this! By entering 'null' into the bind::esri:fieldType column for your 'setting/collecting traps' question, the question won't be recorded in the feature service after the survey, letting you make this question as essentially a UI element only. You can find more ifnromation about this here: Esri custom columns—Survey123 for ArcGIS | ArcGIS
ClaireProctor
HI Benjamin,
BenjaminSperry1
Thank you very much Claire That worked perfectly and thank you for the link it helped answer other questions I had.
