I have a simple map note showing an arrow which shows traffic direction on a street in a web map, created in AGOL in the map viewer. In the associated web map application, the arrow is not visible. The note is in the operational layer listing, and I can zoom to it, but the arrow is not visible in the application. I have no restrictions on the visibility range. I am not sure why the arrow is not visible in the application. Traffic direction has changed from 2-way to 1-way, so it would be useful to have the arrow show. Thoughts?
Which app are you using? Is your webmap/app public? If so can you share the url here?
Hi Kelly!
The app is Esri's Public Parking solution. The map note is called 'Amstel Avenue - One Way' and is in the operational layer list of the application.
Thank you,
Jay
Here is the public link: ArcGIS Web Application
Looks like you are using the Web AppBuilder for ArcGIS so cross posting there might help. I did some testing and the layer does show up in other configurable apps like this one: https://www.arcgis.com/apps/View/index.html?webmap=9641b0e6625849e18f145222b7cfa2e1
When testing your app I took a look at the developer console and there are a few errors about about the Coordinates widget so perhaps try to turn off that widget and see if that helps?
Hi Kelly,
Thanks for the quick response. Right, it is WebAppBuilder, sorry about that, I have been trying several options so I forgot which app I was using. I went into the Edit Application screen from the app's Item page in AGOL, and switched off the Coordinate widget, saved, refreshed, but still no arrow. I am curious as to why, but for now I am switching us back to using the Parking Locator application. I shied away from the app for a couple of reasons, but will revert back to it, as I have a better understanding of the configuration side now.
Sincerely,
Jay
