Portal Collaboration Issue
3025
10-24-2018 06:07 PM
DavidHoy
At my customer's site.
We have established three individual ArcGIS Enterprise 10.6.1 sites using Cloud Builder for AWS Command Line Interface Scripting.
The Sites have all been built using the HA template which provides Portal Content and Config and ArcGIS Server Config on AWS S3 buckets.
We have established a Distributed Collaboration between “Hub” and “Core” sites and created a collaboration workspace providing 1-way Core to Hub sync by registration.
At the first test, we added a pdf file to the “Core” site and shared the item with the Core2Hub-Collab Group associated with the Workspace.
The synchronisation fails – and has done repeatedly – even after dropping and recreating the collaboration/workspace etc.
In the Portal Log on the  receiver “Hub” site – we see the following error message (and no other messages at the same time)
Type
Message
Time
Source
Machine
User
Code
Process
SEVERE
Content store disk space usage threshold of '10' GB reached. Unable to add item while syncing data.
2018-10-24T05:43:03,477
Sharing
10.0.0.32
219999
9424
In the Portal Log on the sender “Core” site – we see the following
Type
Message
Time
Source
Machine
User
Code
Process
INFO
An on-demand synchronization job for items in the collaboration 'Core2Hub', '371f4bc9a9a849c18294c7ba809e4f38' and collaboration workspace 'fd6e0664ac9746128006742434914b2c' with participant '5d0f6a7e-9420-498b-b1e9-43fb22b08fad' has completed
2018-10-24T22:12:40,29
Sharing
10.0.0.17
portaladmin
219999
8256
WARNING
A scheduled job synchronizing items of collaboration 'Core2Hub', '371f4bc9a9a849c18294c7ba809e4f38' and collaboration workspace 'fd6e0664ac9746128006742434914b2c' with participant '61f08ddb-638e-4eac-8846-3f07fda3fd15' has failed.
2018-10-24T22:12:40,24
Sharing
10.0.0.17
portaladmin
219999
8256
WARNING
Sharing
10.0.0.17
portaladmin
219999
8256
WARNING
The import of replication package on portal with id '5d0f6a7e-9420-498b-b1e9-43fb22b08fad' failed.
2018-10-24T22:12:40,19
Sharing
10.0.0.17
portaladmin
219999
8256
INFO
A scheduled job synchronizing the items of collaboration 'Core2Hub', '371f4bc9a9a849c18294c7ba809e4f38' and collaboration workspace 'fd6e0664ac9746128006742434914b2c' is uploading the collaboration replication package (CRPK).
2018-10-24T22:12:39,809
Sharing
10.0.0.17
portaladmin
219999
8256
INFO
Replication package size is '917.92' 'KB'
2018-10-24T22:12:39,725
Sharing
10.0.0.17
portaladmin
219999
8256
INFO
A scheduled job synchronizing the items of collaboration 'Core2Hub', '371f4bc9a9a849c18294c7ba809e4f38' and collaboration workspace 'fd6e0664ac9746128006742434914b2c' found 1 items to send and 0 items to remove.
2018-10-24T22:12:39,572
Sharing
10.0.0.17
portaladmin
219999
8256
INFO
A collaboration scheduled item sync job is processing Enterprise participant with id 61f08ddb-638e-4eac-8846-3f07fda3fd15.
2018-10-24T22:12:38,945
Sharing
10.0.0.17
portaladmin
219999
8256
INFO
A scheduled job synchronizing the items of collaboration 'Core2Hub', '371f4bc9a9a849c18294c7ba809e4f38' and collaboration workspace 'fd6e0664ac9746128006742434914b2c' has started.
2018-10-24T22:12:38,927
Sharing
10.0.0.17
portaladmin
219999
8256
INFO
An on-demand synchronization job for items in the collaboration 'Core2Hub', '371f4bc9a9a849c18294c7ba809e4f38' and collaboration workspace 'fd6e0664ac9746128006742434914b2c' with participant '5d0f6a7e-9420-498b-b1e9-43fb22b08fad' has started
2018-10-24T22:12:38,919
Sharing
10.0.0.17
portaladmin
219999
825
Analysis
By examining the invite/response messages when the collaboration was set up we can identify:
  • The participant '5d0f6a7e-9420-498b-b1e9-43fb22b08fad' is the sending guest “Core” portal
  • The participant '61f08ddb-638e-4eac-8846-3f07fda3fd15' is the receiving host “Hub” portal
We can see the S3 bucket used for Portal Content for the Host in the AWS console
and we can add content manually to this Portal
Why does Hub portal report that less than 10GB is available?
               Perhaps this is a misleading error message and actually means – "cant access the S3 bucket at all" ?
I suspect a permissions problem – but cant see what that may be.
Both Portals are configured to use the same AWS IAM credentials
DavidHoy
Support have confirmed there is a bug implementing Distributed Collaboration with ArcGIS Enterprise using a Cloudstore for Portal Content.
BUG-000117926
The “steps to reproduce” in this bug don’t quite match the case I have – but it is clearly the same issue and should be described as Collaboration fails when the “receiver” of the synchronisation uses Cloud Storage for Portal Content.
So – until there is a patch – don’t setup Collaborations involving Cloudstore for Portal Content.
DavidHoy
BUG-000117926
