Hide LegendLayerLabel and LegendServiceLabel in Legend Widget
1157
7
10-23-2018 08:04 AM
SivaramKrishnan2
New Contributor III
Hi
I'm trying to remove the label from Layer and Service in Legend widget using the following code snippet in WAB 2.6 application.
but when i do any changes in the layer like adding new layer, i'm getting the label visible.
anyone help me to resolve this issue.
Regards
Siva
RobertScheitlin__GISP
Siva,
  Add these mas css rules in the widgets style.css instead of in the widget.js code.
SivaramKrishnan2
New Contributor III
Hi Robert
You are correct, but if i give this rule in style.css, it will always hide the labels for all layers.
here i want to hide for all layers except for one particular layer.
Siva,
  Is it always going to be the first item in the legend?
SivaramKrishnan2
New Contributor III
Robert,
Yes, that will be the first item in the legend.
I'm adding the layers dynamically. So if that particular layer comes we should show the label and not needed for remaining layers.
Note: all the layer names are known.
Thanks & Regards
Siva
Siva,
   This css rule can be added to the widgets css/style.css for your situation then:
.jimu-widget-legend .esriLegendService:first-of-type {
  display: none !important;
SivaramKrishnan2
New Contributor III
Hi Robert
When i include this code in the css/style.css of the legend widget, nothing is visible on the Legend widget.
It is showing an empty Widget without any symbols and classifications.
Regards
Siva
Siva,
  OK I tested that css rule for removing the first whole map service. It seems like you are wanting to remove the first layer of a map service. Here is some code for that (like you started with):
//Add to your define array
'dojo/query'
query
    _createLegendForOperationalLayers: function() {
      var legendParams = {
        arrangement: this.config.legend.arrangement,
        autoUpdate: this.config.legend.autoUpdate,
        respectCurrentMapScale: this.config.legend.respectCurrentMapScale,
        //respectVisibility: false,
        map: this.map,
        layerInfos: this._getLayerInfosParam()
      this.legend = new Legend(legendParams, html.create("div", {}, this.operationalLayersPart));
      this.legend.startup();
      setTimeout(lang.hitch(this, function(){
        query('.esriLegendLayer')[0].style.display="none";
        query('.esriLegendLayerLabel')[0].style.display="none";
      }), 300);
    refreshLegend: function() {
      if(this.legend) {
        var layerInfos = this._getLayerInfosParam();
        this.legend.refresh(layerInfos);
        }), 300);
