Character Point Symbol can rotate sometimes but not others (ArcMap)
1128
10-19-2018 02:12 PM
AmeliaNewsam
I thought for the longest time that I had to convert point symbols to graphics in order to rotate them, but then just the other day I discovered that I WAS able to rotate them using the rotate tool on the editing ribbon.  This is the same shapefile template I've been using for years and couldn't rotate, then all of a sudden I CAN rotate... very confused.  I noticed that the attribute table does have a field called "rotation", and when I scroll down, it is all zeros until I get to the symbols that I was magically able to rotate, in which there are now numbers representing the degrees rotation, which were put there automatically i guess, because I just rotated them manually.  I then created a new shapefile and added a field called rotation, but have not been successful in rotating those symbols by hand.  Is this just some weird bug, or is there a setting that I haven't discovered that I am somehow inadvertently turning on and off?
Amy
Scott_Harris
Hi Amy,
Check out this documentation: Rotating point feature symbols—Help | ArcGIS Desktop
The rotate function can reference a rotation field, but it doesn't create the field. If a field is set up, and you use the Rotate tool, it will modify the value in the rotation field.
Scott_Harris
Hi Amy,
AmeliaNewsam
OK, please ignore the paragraph below (my original response)  I realize now that I completely misread Scott's reply to my question.  Yes, I understand now and will take a look at the symbol's properties to see if I can set an angle field.  Thank you!
OLD:  Let me try to restate my question: I use shapefiles with character point features, and a couple of years ago when I first started working with them, I had tried to rotate them, but they would just snap back into place when I let go, so instead I converted to graphics.  Then, just recently, for some reason I tried to use the rotate button again, and this time it worked:  the points  stayed rotated, AND, when I looked at the attribute table, I saw that a value had been placed into the field called rotation (I did not put the values there - they were put there automatically when I rotated the points by hand).  So, encouraged by this, I tried to create a new shapefile, and included a field called rotation, and tried to rotate those points, but they did NOT stay rotated and did not automatically put a value into the field.  I think I must have just stumbled across a very strange bug, because I swear to you that the points stayed rotated and they had values in a rotation field that I did not enter.
