Drop down on search field
2221
11
10-16-2018 11:28 PM
irtizahussain
How can i add the fields of my layer on search widget so that i just select the field name from drop down and search instead of write the name of the field !! Need help , is there any sample code for this
RobertScheitlin__GISP
That's why I asked what version you were using the other day.
<!DOCTYPE html>
<html>
<head>
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
  <title>Drop Down Test</title>
  <link rel="stylesheet" href="http://js.arcgis.com/4.9/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="https://js.arcgis.com/4.9/esri/css/main.css">
  <script src="https://js.arcgis.com/4.9/"></script>
  <style>
    html,
    body,
    #mainWindow {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
    body {
      background-color: #FFF;
      overflow: hidden;
      font-family: "Trebuchet MS";
    #header {
      height: 3%;
      overflow: auto;
  </style>
  <script>
    var map;
    require([
      "esri/Map",
      "esri/views/MapView",
      "dojo/on",
      "esri/tasks/support/Query",
      "esri/layers/FeatureLayer",
      "dojo/store/Memory",
      "dojo/_base/array",
      "dojo/_base/lang",
      "esri/request",
      "dojo/parser",
      "dijit/registry",
      "dijit/layout/BorderContainer",
      "dijit/layout/ContentPane",
      "dijit/form/Button",
      "dijit/form/ComboBox",
      "dojo/domReady!"
    ], function(
      Map, MapView, on, Query, FeatureLayer, Memory, array, lang, esriRequest, parser, registry
      parser.parse();
      map = new Map({
        basemap: "topo"
      var view = new MapView({
        container: "map",
        map: map,
        center: [-98.1883, 37.0868],
        zoom: 5
      esriRequest('http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/3/query?where=1%3D1&outF...',
        responseType:'json',
        timeout:15000
      }).then(lang.hitch(this,function(response){
        var store2 = new Memory({data:[]});
        registry.byId("stateSelect").set('store',store2);
        var data = array.map(response.data.features,lang.hitch(this,function(feat, index){
          var name = feat.attributes.STATE_NAME;
          var value = feat.attributes.STATE_NAME;
          var dataItem = {
            value:value
          return dataItem;
        store2 = new Memory({data:data});
      var States = new FeatureLayer({
        url: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/3",
        outFields: ["*"]
      var Counties = new FeatureLayer({
        url: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/2",
        outFields: ["*"]
      //map.addMany([States,Counties]);
      app = {
        zoomRow: function(id, which){
          var sym = {
            type: "simple-fill",  // autocasts as new SimpleFillSymbol()
            color: [255, 0, 0, 0.5],
            outline: {  // autocasts as new SimpleLineSymbol()
              color: [128, 128, 128, 1],
              width: "0.5px"
          }, gra;
          view.graphics.removeAll();
          var query = States.createQuery();
          var thePoly, theExtent;
          if(which == "State"){
            query.outFields=[];
            query.outSpatialReference = view.spatialReference;
            query.where = "STATE_NAME='" + (id).toString() + "'";
            console.info(query.where);
            query.returnGeometry = true;
            States.queryFeatures(query).then(function(response){
              gra = response.features[0];
              gra.symbol = sym;
              view.graphics.add(gra);
              thePoly = gra.geometry;
              theExtent = thePoly.extent.expand(2); //Zoom out slightly from the polygon's extent
              view.goTo(theExtent);
            esriRequest("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/2/query?where=STATE_NAME...'" + id.toString() + "'&outFields=NAME&returnGeometry=false&orderByFields=NAME&returnDistinctValues=true&f=json",
              responseType: "json",
              timeout:15000
              registry.byId("countySelect").set('store',store2);
                var name = feat.attributes.NAME;
                var dataItem = {
                return dataItem;
              document.getElementById('countySelect').value = "Select County";
          }else if(which == "County"){
            query = Counties.createQuery();
            var county = (id).toString();
            county = county.replace(" County", "");
            query.where = "NAME='" + county + "'";
            query.outFields=[];
            Counties.queryFeatures(query).then(function(response){
              gra.symbol = sym;
  </script>
</head>
<body class="claro">
  <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false" style="padding:0px;margin:0px;">
    <div id="header" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'" style="overflow:hidden;border:none;border-bottom: 3px solid #CC9900;font-family: Windows;font-size:14pt; color: #FFFFFF;background: #000000; "> Select a State/County and zoom to it on the map:
      <input id="stateSelect" data-dojo-type="dijit/form/ComboBox" value="Select State" onchange="app.zoomRow(document.getElementById('stateSelect').value, 'State');" data-dojo-props="maxHeight: 200" />
      <input id="countySelect" data-dojo-type="dijit/form/ComboBox" value="Select County" onchange="app.zoomRow(document.getElementById('countySelect').value, 'County');" />
      <input type="hidden" name="stateabbr" id="stateabbr" />
    </div>
    <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'" style="width:100%;height:95%;border:none;padding:0px;margin:0px;"></div>
  </div>
</body>
</html>
Irtiza,
   When do you have to type the field name into the search widget..? Normally you configure the search widgets sources and in the source you define the fields that will be searched and then the only thing you type into the search widgets input box is the search term.
irtizahussain
i want to make the search in a way where i don't have to type any thing i just select the fields and it search for me.It is same as drop down button works in html , unfortunately i have no idea how to implement this!!
Irtiza,
   Then the search widget is way to much for your needs. You just need to add a html select and on click have it execute a queryTask.
irtizahussain
As i'm a newbie i have no idea how to write such query!!
Irtiza,
   You talking 3.x or 4.x API?
Here is a 3.x sample:
<!DOCTYPE html>
<html>
<head>
  <link rel="stylesheet" href="http://js.arcgis.com/3.26/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.26/dojo/resources/dojo.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.26/esri/css/esri.css">
  <script src="http://js.arcgis.com/3.26/"></script>
  <style>
    html,
    body,
    #mainWindow {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
    body {
      overflow: hidden;
    #header {
      height: 3%;
      overflow: auto;
  </style>
  <script>
    var map;
    require([
      "esri/map",
      "dojo/on",
      "esri/tasks/query",
      "dojo/_base/array",
      "dojo/_base/lang",
      "esri/request",
      "dojo/json",
      "dojo/parser",
      "dojo/domReady!"
    ], function(
      Map, on, Query, FeatureLayer, Memory, array, lang, esriRequest, json, parser
      parser.parse();
      map = new Map("map", {
        basemap: "topo",
        zoom: 5
      esriRequest({
        url: 'http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/3/query?where=1%3D1&outF...',
        content:{
          f:'json'
        handleAs:'json',
        callbackParamName:'callback',
        timeout:15000
        dijit.byId("stateSelect").set('store',store2);
        var data = array.map(response.features,lang.hitch(this,function(feat, index){
          var dataItem = {
            value:value
          return dataItem;
      var States = new FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/3", {
        mode: FeatureLayer.MODE_SELECTION,
        outFields: ["*"]
      var Counties = new FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/2", {
        outFields: ["*"]
      map.addLayers([States,Counties]);
      app = {
          States.clearSelection();
          Counties.clearSelection();
          var query = new Query();
            States.selectFeatures(query, FeatureLayer.SELECTION_NEW, function (features) {
              thePoly = features[0].geometry;
              theExtent = thePoly.getExtent().expand(2); //Zoom out slightly from the polygon's extent
              map.setExtent(theExtent);
            esriRequest({
              url: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/2/query?where=STATE_NAME...'" + id.toString() + "'&outFields=NAME&returnGeometry=false&orderByFields=NAME&returnDistinctValues=true&f=json",
              content:{
                f:'json'
              handleAs:'json',
              timeout:15000
              dijit.byId("countySelect").set('store',store2);
                var dataItem = {
                return dataItem;
            Counties.selectFeatures(query, FeatureLayer.SELECTION_NEW, function (features) {
  </script>
</head>
    </div>
  </div>
</body>
</html>
irtizahussain
Robert Thanks for the help,
This is exactly what i want to do, thanks alot for this. The problem is my project is on 4.9 API version,code is not running  when i change the version of this code. How can i convert the version of this code into 4.9 !!
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #mainWindow {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
    body {
      overflow: hidden;
    #header {
      height: 3%;
      overflow: auto;
  </style>
  <script>
    var map;
    require([
      "esri/Map",
      "dojo/on",
      "dojo/_base/array",
      "dojo/_base/lang",
      "esri/request",
      "dojo/parser",
      "dijit/registry",
      "dojo/domReady!"
    ], function(
      parser.parse();
      map = new Map({
        basemap: "topo"
        container: "map",
        map: map,
        zoom: 5
        timeout:15000
          var dataItem = {
            value:value
          return dataItem;
        outFields: ["*"]
        outFields: ["*"]
      app = {
          var sym = {
              width: "0.5px"
          }, gra;
            query.outFields=[];
              gra.symbol = sym;
              timeout:15000
                var dataItem = {
                return dataItem;
            query.outFields=[];
              gra.symbol = sym;
  </script>
</head>
    </div>
  </div>
</body>
</html>
irtizahussain
Robert Scheitlin, GISP‌ ooh thank u soo much ,  you save my life.Stay blessed
