%Name% variable error
461
10-16-2018 09:51 AM
CarlTownsend1
New Contributor III
I'm getting an error when I try in model builder to name the output of a buffered feature class based on the name of an input point file.
For example, I have in my input feature class 'teddy_bear_locations' and in my output the variables %Data Workspace%\Buffer_'%Name%' but when I look in the geodatabase, the output name is just Buffer_
I would like to have the output buffer as Buffer_teddy_bear_locations OR teddy_bear_locations_Buffer
If I use %Data Workspace%\%Name% it fails
if I use %Data Workspace%\Buffer_%Name% it fails with an invalid character error.
if I use %Data Workspace%\%Name%_Buffer it fails with an invalid character error.
The parse path is set to type NAME
The only time it doesn't fail is when I wrap the %Name% in quotes ' '
Not sure if this is a syntax error or anything else. I'm scratching my head here. This ought to be very simple... From all the examples I've seen it should work.
Thanks!
DuncanHornby
MVP Notable Contributor
You need to add a screen shot of your model if you want anyone to answer this as it could be multiple issues.
ChrisDonohue__GISP
Some questions:
  • How is the data stored?   Feature Class in a File Geodatabase?  Enterprise Geodatabase (SDE)?  Shapefile?  Personal Geodatabase?
  • Which software and what version of the software are you using?  ArcGIS Desktop?  ArcGIS Pro?
Chris Donohue, GISP
CarlTownsend1
New Contributor III
It turned out to be an IT/network issue....
