Append survey123 points to workforce assignments
1640
21
10-16-2018 07:39 AM
joerodmey
Looking to append my existing survey123 points automatically to workforce as assignments. Can this be done without Python?
by Anonymous User
Not applicable
Hi Joe,
You don't necessarily need Python. Workforce assignments are stored in a Feature layer. So anything that can add features to a feature layer can accomplish this. That said, Python is the most popular tool used.
joerodmey
Aaron,
How would any new point that is created in Survey123 be added to Workforce at the same time?
by Anonymous User
Not applicable
The two options for that workflow are:
1. Using webhooks with some kind of custom endpoint
2. Polling the survey123 features layer using a script. You'd write a Python (or other language) script that runs every 5 minutes (or whatever interval you decide) on a server. The script identifiers new features and then will create an assignment in the Workforce Assignments layer.
joerodmey
What I did was just place the Survey123 feature service in both the worker and dispatcher web maps. Seems to be working that way. Can I trip emails once an assignment has been set to complete, etc?
by Anonymous User
Not applicable
Not out of the box. You would need to configure a script to poll the assignments feature layer and trigger an email. An example Python script that sends a Slack message is shown here.
joerodmey
Integromat an option?
Can data be passed into Workforce to help the field worker understand some details of the request such as what the issue is without the dispatcher typing out the info manually?
by Anonymous User
Not applicable
I'm not familiar with Integromat so I can't really comment on it.
The mobile app does not support the creation of assignments on device. So you cannot pass in information to create an assignment on device. It must be created using something else first (Dispatcher App, Script, Webhook...).
Most users typically use Workforce as the gateway into the other apps like Collector or Survey123. A Workforce Project can be configured to pass information from an assignment into a Survey123 or Collector form. We currently don't support going the other way around.
joerodmey
You mentioned webhooks, how are you suggesting to use those? If I could use the webhook from survey123 to populate assignments in workforce, that would be great.
by Anonymous User
Not applicable
My understanding is that you configure your Survey form with a webhook that fires when the survey is completed. The webhook (url) that you configure will have to have custom code that handles creating the Workforce assignment. For example, you'd need to configure a web-server that has an endpoint that accepts the feature and creates the assignment. We've prototyped something similar and used AWS Lambda with API Gateway to act as the webhook handlers. If you are using Python, you could create a Flask or Django app that creates the assignment.
I hope that helps.
