Have Z-enabled line, want to generate Z-enabled points on line.
619
10-12-2018 06:23 AM
RockRunEnterprises
I have 3D line features and want to generate 3D points at a predetermined interval. I have performed the "Generate Points Along Line" process but the subsequent points do not have Z values attached. What am I missing?screenshot
DuncanHornby
MVP Notable Contributor
Looking at the help file for Generate Points Along Line, it does not state under the environment settings that it honours Z values, may be one of the ESRI development team could improve that aspect of the tool, create points that also have MZ values when the polyline has MZ values?
I'm not aware of any tool that can extract Z values from a polylineZ. May be there is?
I  would probably use a combination of tools, something like vertices to points, then Add Z Information (3D Analyst)
and then transfer the Z values with may be  spatial join?  But are you assuming a linear change in Z values along your line?
JohnBrand
New Contributor III
I'm running into the same problem.  Apparently the method used within the generate points along line tool only works in 2d.
https://community.esri.com/t5/arcgis-pro-questions/generate-points-along-a-3d-line/m-p/1205885#M5900...
