I'm finishing up my story map, but I have a couple issues. When I view the application, there is a little 'edit' button in the upper right. I'm not quite sure why this is here. Also, if I go to 'configure application' there is a constant rolling 'checking' button. It seems to never stop. Are these normal or should I try to figure out how to get rid of them?
Thanks.
url is https://wadnr.maps.arcgis.com/apps/Shortlist/index.html?appid=98a7fe4ea3764440ad59f0d9b0b280e3
-Elizabeth Eberle
Hi Elizabeth -- Sorry you are having some issues with your story. The Edit button is visible only by you when you are logged into your account. It's just a shortcut for you to open the Builder. Others won't see that, and you won't see it if you are logged out or access your public story map in a private/incognito browser window.
I'm not sure about the checking... button. That should go away after the checks are finished, but it sounds like one of the checks is hanging. There didn't appear to be anything wrong with your story when I just looked at it. You could try logging out and back into your account and/or clearing your browser cache to see if that goes away. If those don't work and you're still concerned about it I'd suggest that you contact Esri Support since that appears to be an issue specific to your story.
