Fixing the extent of the source
350
10-11-2018 04:00 AM
Rens_Vermeltfoort
Hello everyone,
the extent of the source is off 0,0001 m. I have tried different ways of fixing this but none of them worked properly. Do any of you know the easiest way to fix this?
Greetings,
Rens
AndrewSakowicz
this does not appear to be related to ArcGIS Monitor.
DanPatterson_Retired
that is 0.00001 m shift or one tenth of a millimeter.  Compared to your 4000 meter extent, I suspect that some floating point representation issue and the 'error' is virtual.
What are you doing that this value will be of concern?
What is your geodatabase XY resolution and tolerance?
XY Resolution (Environment setting)—Geoprocessing | ArcGIS Desktop
XY Tolerance (Environment setting)—Geoprocessing | ArcGIS Desktop
The default is 1 mm (0.001m) and you are 2 orders of magnitude below this, and you are using a double sterographic projection which would not even have a accuracy remotely approaching this value
