Using arcpy.mapping.AddLayer to import raster in RGB instead of single-band stretched symbology
2599
10-09-2018 06:00 AM
HannesZiegler2
Occasional Contributor II
Hi, I am working with a simple script that imports geo-referenced rasters corresponding to selected polygons in a featureclass layer. The rasters import just fine, but the issue is that they import as single band streched rasters and I have to go into the layer symbology tab under properties and then change the imported rasters to RGB composite individually. Does anyone have any idea how I could skip that manual step and code for this to happen automatically? The relevant code snippet looks like this:
  1. #Fetch selected rasters and add to current map document, first data frame
  2. mxd = arcpy.mapping.MapDocument("CURRENT")
  3. df = arcpy.mapping.ListDataFrames(mxd, "*")[0]
  4. arcpy.AddMessage(len(docs))#DEBUG#
  5. for i, page in enumerate(docs):
  6.         arcpy.AddMessage(i)
  7.         newlayer = arcpy.mapping.Layer(page)
  8.         arcpy.mapping.AddLayer(df,newlayer, "TOP")
Thank you!
Ystad1
To do this you need to first set the RGB composite manually on one raster and save it as a lyr file. You can then use the lyr file to update the symbology of the raster that you have added with arcpy.mapping.Updatelyr. Here is a script that i wrote to add all of the .tif files in a folder to a mxd and set the symbology as RGB.
#-*- coding: utf-8 -*-
import glob
import os
import arcpy
#Count number of files added to mxd
count = 0
#Paths
path = r"V:/Path/to/raster/folder"
MXD = r"V:/Path/to/arcmapdocument/mymap.mxd"
sourceLayer = arcpy.mapping.Layer(r"V:/path/to/layerfile/rgb.lyr")
mxd = arcpy.mapping.MapDocument(MXD)
df = arcpy.mapping.ListDataFrames(mxd)[0]
for file in os.listdir(path):
    if file.endswith(".tif"):
        name = file.split('.')[0]
        print name
        rasterPath =os.path.join(path, file)
        updatelyr = arcpy.mapping.Layer(rasterPath)
        arcpy.mapping.UpdateLayer(df, updatelyr, sourceLayer, True)
        arcpy.mapping.AddLayer(df, updatelyr, "BOTTOM")
        count = count + 1
print count
mxd.save()
Hope this helps!
HannesZiegler2
Thank you, this worked!
It's really disappointing that arcpy.mapping doesn't let you edit layer properties directly in script though 😕
DanPatterson_Retired
Symbology—ArcPy | ArcGIS Desktop
mp in ArcGIS Pro, example 2 gives an example or changing a raster's classification field, and color ramp. I doubt that this is new to Pro, so the equivalent might exist in the 'mapping' model
