createContext failed: EGL_SUCCESS
759
10-07-2018 06:53 PM
chenyangyang
SDK Version 100.3
Android 8.1.0,level 27
This problem has been bothering us.
ShellyGill1
Hi there - I'm assuming here you're simply trying to create a SceneView, and the exception happens at that point - is that correct? What device are you seeing this error happening on? Can you give details of the OpenGL support on the device? (you can find a number of apps in the Play Store which report this information for you - I have used one called 'GLview' in the past). You should be able to create a SceneView on pretty much any modern device, but 3D does require a lot of system resources, so we would strongly recommend using a high-end device, and one that has OpenGL 3.
Regards,
Shelly
