Position/location Point Display in QML
672
10-08-2018 10:37 AM
GiatriLalla
New Contributor III
Good Day,
How can I get a position/location point from the locationDisplay? I want to get that point. I am using the code below but I nothing happens when I click the button.
import QtQuick 2.7
import QtQuick.Controls 2.1
import QtPositioning 5.3
import QtSensors 5.3
import ArcGIS.AppFramework 1.0
import ArcGIS.AppFramework.Controls 1.0
import Esri.ArcGISRuntime 100.2
App {
    visible: true
    //Create MapView that contains a Map
    MapView {
        anchors.fill: parent
        //Nest the Map as a child of the MapView
        Map {
    //Nest the ArcGISTiledLayer to add it as one of the Basemap's baselayers
            ArcGISTiledLayer {
                url: "https://services.arcgisonline.com/arcgis/rest/services/Polar/Antarctic_Imagery/MapServer"
            locationDisplay {
                positionSource: PositionSource {
        onStatusChanged: {
            if (loadstatus === Enums.MapStatusReady) {
                ps.active = true;
        Button {
            anchors {
                left: parent.left
                top: parent.top
                margins: 10
            text: "get point"
            onClicked: {
                var point = mapView.locationDisplay.mapPoint;
                console.log("x", point.x, "y", point.y, "wkid", point.spatialReference.wkid)
HeathcliffRongo
New Contributor III
I can't see where "mapView" is defined in your sample code. Is it defined in your actual code?
GiatriLalla
New Contributor III
I think its suppose to be MapView*
GiatriLalla
New Contributor III
It is, however unintentionally. This problem was re-worded as well as the code was changed and posted in the forum as another question.
