AnsweredAssumed Answered
Import Arcpy module error
Question asked by myriadbanshee on Oct 5, 2018
Latest reply on Oct 5, 2018 by bixb0012
Hello there,
I am using ArcGIS 10.5 on Windows 7 64 bit machine with Python 2.7.15
I have reached the end of all the supporting documentation I can find to resolve this issue.
I have reinstalled ArcGis 10.5.1  and then 10.5– a clean install where I removed all traces of python (uninstalling via Control Panel and removing any folders with ArcGIS
and python in it). I am unable to import arcpy using the IDLE, although when I go to ArcGIS IDLE GUI, I can.
This works.
This does not.
In the second instance, I am trying to run a script held in one of the values in sys.path (i.e. “Working scripts”)
I have tried creating a PY_HOME variable, adding the path ways to the python modules to the Path environment variable, I have also added the path of the sys.executable into the PYTHONPATH variable i.e. C:\Python27\ArcGIS10.5\pythonw.exe
There is no python.exe registry created in HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Python.exe.
I don’t know what else to try, so would appreciate someone looking into this. I attached a document of my workings out.
Dan.B
Outcomes
