AnsweredAssumed Answered
How make custom basemaps toogle
Question asked by tokar.andriiesri-ua-esridist Employee on Oct 5, 2018
Latest reply on Oct 8, 2018 by rscheitlin
Hi, I have such code. Need to show only custom basemaps (that published as services)  at 2 different frames with sync effect. Why It doesn't work, how fix it?
script>
    var map, map2;
    require(["esri/map", "dojo/on", "esri/dijit/Basemap",
            "esri/dijit/BasemapGallery", "esri/dijit/BasemapLayer", "esri/arcgis/utils", "dojo/parser",
            "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/TitlePane", "dojo/domReady!"],
        function (Map, on, Basemap, BasemapGallery, BasemapLayer, arcgisUtils, parser) {
            parser.parse();
            var basemaps = [];
            var customBasemapLayer1 = new BasemapLayer({
                url: "http://ags-pro.ecomm.pp.ua/portal/apps/webappviewer/index.html?id=6e5ced0707fd44219eb95209680784d9"
            var customBasemapLayer2 = new BasemapLayer({
            var customBasemap1 = new Basemap({
                layers: [customBasemapLayer1],
                title: "custom Basemap1",
                thumbnailUrl: "custom.png"
            var customBasemap2 = new Basemap({
                layers: [customBasemapLayer2],
                title: "custom Basemap2",
            basemaps.push(customBasemap1);
            basemaps.push(customBasemap2);
            map = new Map("map", {
                basemap: "customBasemap1", //For full list of pre-defined basemaps, navigate to http://arcg.is/1JVo6Wd
                center: [37.15, 48.18,], // longitude, latitude
                zoom: 12
            map2 = new Map("map2", {
                basemap: "customBasemap2", //For full list of pre-defined basemaps, navigate to http://arcg.is/1JVo6Wd
                zoom: 12
            //add the basemap gallery, in this case we'll display maps from ArcGIS.com including bing maps
            var basemapGallery = new BasemapGallery({
                showArcGISBasemaps: false,
                map: map,
                basemaps: basemaps,
            }, "basemapGallery");
            basemapGallery.startup();
            basemapGallery.on("error", function (msg) {
                console.log("basemap gallery error:  ", msg);
            var basemapGallery2 = new BasemapGallery({
                map: map2,
                basemaps: basemaps,
            }, "basemapGallery2");
            basemapGallery2.startup();
            basemapGallery2.on("error", function (msg) {
            //Fires when the zoom is complete.
            map.on("zoom-end", function (evt) {
                map2.setZoom(evt.target.__LOD.level);
            map2.on("zoom-end", function (evt) {
                map.setZoom(evt.target.__LOD.level);
            // Fires when a mouse button is pressed down and the user starts to drag the mouse.
            map.on("mouse-drag-start", function (evt) {
                //The resume() method will cause the listener to be called again.
                handler1.resume();
            map2.on("mouse-drag-start", function (evt) {
                handler2.resume();
            //https://developers.arcgis.com/javascript/3/jsapi/map-amd.html - see docs
            /*The pausable() method provides a means for pausing an event listener, while still preserving the listeners order and state.
             The pausable() method can be called just like on(). The only difference is the returned signal handler will include pause() and resume() methods.*/
            //Fires when the pan is complete.
            var handler1 = on.pausable(map, "pan-end", function (evt) {
                //The pause() method will cause the listener to not be called when the specified event takes place
                handler2.pause();
                map2.centerAt(evt.extent.getCenter());
            var handler2 = on.pausable(map2, "pan-end", function (evt) {
                handler1.pause();
                map.centerAt(evt.extent.getCenter());
</script>
<body class="claro">
<header>
    <div class="toogle" style="position:absolute; left:100px; top:20px; z-Index:999;">
        <div data-dojo-type="dijit/TitlePane"
             data-dojo-props="title:'Switch Basemap1', open:false">
            <div data-dojo-type="dijit/layout/ContentPane"
                 style="width:380px; height:280px; overflow:auto;">
                <div id="basemapGallery"></div>
            </div>
        </div>
    </div>
    <div class="toogle" style="position:absolute; right:100px; top:20px; z-Index:999;">
             data-dojo-props="title:'Switch Basemap2', open:false">
                <div id="basemapGallery2"></div>
            </div>
        </div>
    </div>
</header>
<div class="mapContainer">
    <div id="map" class="claro"></div>
    <div id="map2" class="claro"></div>
</div>
Outcomes
