I am using the "Geopoint" feature in my survey. I would like the data in decimal degrees but it converts the input to degrees, minutes seconds. Is there a way to change this?
Thank you Ismael for your speedy response. I went into 123Survey Connect and changed the coordinate format. When I tried to publish it I got an error message that said “Unable to add feature service layer definition” Error code 400.
Hi Channel. The error you are getting has no connection with the coordinate format change you applied. You may want to open a new thread on that specific error (and provide a copy of your XLSForm in the thread for further investigation).
The available coordinate formats are:
More info on things you can do with coordinate formats:Working with USNG and MGRS in Survey123 for ArcGIS
