Hosting Server for Portal
389
10-03-2018 11:28 AM
RebeccaRichards_Steed
Friends,
I am setting up an in-house ArcGIS Portal at a cancer research facility. The software is local, on a local serer, and is protected behind a firewall. I have been able to set-up the portal and get to the home page, create a map with default basemaps, but I cannot add data to my map that I have uploaded to My Content. I need something called a "hosting server" to access the data I want displayed on my maps and apps. Can anyone elaborate on this, and please no jargon. I am not a server IT person.
Thanks for your help!
RyanUthoff
Occasional Contributor III
In order to upload hosted content to Portal, you need the ArcGIS Data Store installed. Have you installed the ArcGIS Data Store?
JonathanQuinn
Esri Notable Contributor
You'll also need ArcGIS Server.
Below is a link to a tutotial on setting up your deployment. It goes through each step you'll need to get a complete deployment:
Tutorial: Set up a base ArcGIS Enterprise deployment—ArcGIS Enterprise | ArcGIS Enterprise
An easier approach, though is to use the ArcGIS Enterprise Builder, which simplifies the process of creating your deployment. I strongly suggest you use the Builder rather than set everything up yourself:
What is ArcGIS Enterprise Builder?—ArcGIS Enterprise | ArcGIS Enterprise
You'll just need help from your IT staff on getting a certificate to use for the web server that will host the web adaptors.
