Web App Builder - Problème d'import de carte depuis Arcgis Online
458
10-03-2018 04:26 AM
YoussefM_HAMDI1
Bonjour,
Je viens de commencer à créer des cartes interactives avec cet outil puissant Arcgis, J'utilise  arcgis online avec web app builder for Arcgis, et j'ai un problème d'importation de la carte à partir de mon compte arcgis online depuis 3 semaines :
message : fail to import . the theme used by the app is in a newer version
La version de Web app builder est 2.9
Pourriez vous m'aider à régler ce problème.
Merci.
Google Translate:
I just started to create interactive maps with this powerful tool Arcgis, I use arcgis online with web app builder for Arcgis, and I have a problem importing the card from my account arcgis online for 3 weeks:
message: fail to import. the theme used by the app is in a newer version
The version of Web app builder is 2.9
Could you help me solve this problem?
Thank you.
RobertScheitlin__GISP
Youssef,
   The issue is that AGOL WAB is version 2.10 right now and WAB Developer is still 2.9 of a little while. Normally WAB Dev will release a few weeks after AGOL is released so it should not be long now before WAB Dev releases 2.10 version. Until then you can not import a WAB AGOL 2.10 app into WAB Dev.
DerekLaw
Esri Esteemed Contributor
Hi Youssef,
Just to add onto Robert Scheitlin, GISP's post, you could use the beta release of Web AppBuilder for ArcGIS Developer Edition v2.10.
https://community.esri.com/groups/web-app-builder-custom-widgets/blog/2018/09/27/web-appbuilder-deve...
Hope this helps,
