Apply Asset Package: Failed to execute (AssetPackageToUtilityNetwork).
1088
10-03-2018 04:27 AM
ApatorRector
Hi, i try to install Utility Network example by Get started with the Electric Utility Network Configuration—Get Started | ArcGIS for Electric  but I get an error when i run the Apply Asset Package tool:
Parametry
Asset Package C:\Users\przemek\Documents\ArcGIS\Packages\ElectricUtilityNetwork_442C972A-3213-4DC5-860F-D81FBB1435A5\p20\electric_assetpackage.gdb
Domain Networks to apply Structure;ElectricDistribution;ElectricTransmission
Input Utility Network C:\Users\przemek\Documents\ArcGIS\Packages\ElectricUtilityNetwork_442C972A-3213-4DC5-860F-D81FBB1435A5\kotprod.sde\GEODB.Electric\GEODB.Utilit_Network
Load data true
Calculate Spatial Index and Analyze true
Output Utility Network
Informacje
Start Time: 3 października 2018 12:25:12
Running script AssetPackageToUtilityNetwork...
ArcGIS Pro 2.2.2.12813
untools 2.2.0
Item Field OID Value Message Level
0 B_Subnetwork_Diagrams diagram_template 4 Basic Diagram does not exist error
1 B_Subnetwork_Diagrams diagram_template 3 Basic Diagram does not exist error
2 B_Subnetwork_Diagrams diagram_template 1 Basic Diagram does not exist error
3 B_Subnetwork_Diagrams diagram_template 2 Basic Diagram does not exist error
Failed at 3 października 2018 12:26:01 (Elapsed Time: 49,74 seconds)
Can someone help me?
PaulLeBlanc1
Apator, is your OS and ArcGIS Pro using the Polish language pack?
If you look inside the "B_DiagramTemplate" table, does it have 3 entries (including Basic)?
MikeMillerGIS
Esri Frequent Contributor
could you post a screen shot of the network properties of the utility network
PaulLeBlanc1
I tested with a Polish LP. Inside the asset package, you can use Calculate Field—Data Management toolbox | ArcGIS Desktop to replace "Basic" with "Bazowy". You should then be able to apply the asset package then:
ApatorRector
Hi Paul, thank you for the answer.
I made your instruction and it works fine now.
It was very helpful, thank you again.
