AnsweredAssumed Answered
sync_replicated_items error
Question asked by spredar on Oct 1, 2018
I am attempting to use the sync_replicated_items class from the #ArcGIS API for Python to synchronize two services, one on AGOL and one on an internal portal but receive a Runtime error code 500.  I created the internal portal feature service using the create_replica_item class, and both have the same replica name and ID (although the internal is all caps and external id is lower case, if this makes a difference).  The script successfully connects to both AGOL and our internal portal.
Error below
---------------------------------------------------------------------------RuntimeError                              Traceback (most recent call last)<ipython-input-12-3b2f687ad756> in <module>()     19 print("syncing services")     20 ---> 21 sync_extint = ext_fs.replicas.sync_replicated_items(ext_item,int_item,'NWW Spot Report')     22      23 print(sync_extint)C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\features\managers.py in sync_replicated_items(self, parent, child, replica_name)    632             if child_replica_id and \    633                parent_replica_id:--> 634                 import tempfile, os    635                 child_replica = child_replicas.get(replica_id=child_replica_id)    636                 parent_replica = parent_replicas.get(replica_id=parent_replica_id)C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\features\managers.py in get(self, replica_id)    389                            when the replica was created.    390         """--> 391         return self._fs._replica_info(replica_id)    392     393     # ----------------------------------------------------------------------C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\features\layer.py in _replica_info(self, replica_id)   1509         }   1510         url = self._url + "/replicas/" + replica_id-> 1511         return self._con.get(path=url, params=params, token=self._token)   1512    1513     # ----------------------------------------------------------------------C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\_impl\connection.py in get(self, path, params, ssl, compress, try_json, is_retry, use_ordered_dict, out_folder, file_name, force_bytes, add_token, token)    875                                     return self.get(path=path, params=params, ssl=True, compress=compress, try_json=try_json, is_retry=True)    876 --> 877                             self._handle_json_error(resp_json['error'], errorcode)    878                             return None    879                 except AttributeError:C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\_impl\connection.py in _handle_json_error(self, error, errorcode)   1174    1175         errormessage = errormessage + "\n(Error Code: " + str(errorcode) +")"-> 1176         raise RuntimeError(errormessage)   1177    1178 class _StrictURLopener(request.FancyURLopener):RuntimeError:  (Error Code: 500)
Outcomes
