What is the matrix
1869
10-02-2018 11:22 AM
KathyMulcahy
Frames table schema
ArcMap 10.4
This is a list of recognized and supported fields for the frames table of the frame camera raster type. This table enables specification of parameters that control exterior orientation (EO).
The frames table can be stored in several formats: a geodatabase table, feature class table, raster catalog, or a *.csv file. Listed below are all of the supported fields. At the end of this page is an example frames table.
Note:
A parameter definition in the frames table take precedence over any duplicate definitions within the cameras table.
List of fields supported in the frames table
Field nameField typeData typeDescription
Raster
Required
String
The path to the image file or the RASTER column, if you are using a raster catalog.
CameraID
Required
String
A unique field within the cameras table, from where the orientation parameters are loaded.
PerspectiveX
Required
Numeric
The x-coordinate of the perspective center, in the ground coordinate system. The units are in the coordinate system units.
The geographic coordinate system units are not currently supported. Specify the PerspectiveX value in projected coordinate system units.
PerspectiveY
Required
Numeric
The y-coordinate of the perspective center in the ground coordinate system. The units are in the coordinate system units.
The geographic coordinate system units are not currently supported. Specify the PerspectiveY value in projected coordinate system units.
PerspectiveZ
Required
Numeric
The z-coordinate value of the perspective center in the ground coordinate system. The units are the z coordinate system units if z coordinate system exists, otherwise it defaults to meter.
Omega
Required*
Numeric
The rotational angle of the camera's x-axis in degrees. The units are in decimal degrees.
Phi
Required*
Numeric
The rotational angle of the camera's y-axis in degrees. The units are in decimal degrees.
Kappa
Required*
Numeric
The rotational angle of the camera's z-axis in degrees. The units are in decimal degrees.
Matrix
Required*
String
The matrix describing the transformation from image-space to map-space.
The matrix is specified as nine floating-point values, which are delimited by spaces or semicolons.
Shape
Optional
Geometry
The polygon identifying the region containing valid image data. This polygon becomes the footprint of the corresponding mosaic dataset item.
Name
Optional
String
An alias name to identify the image. If this is left blank, the image file name is used.
Tag
Optional
String
A tag that enables the image to participate in a function template.
GroupName
Optional
String
An optional categorization for images. All images with the same group name participate together in a function template.
StripName
Optional
String
The name of the strip (run).
SRS
Optional
String
Coordinate system associated with the perspective point as WKT-PRJ string or file path or EPSG code. Defaults to data-specified or mosaic dataset SR. The spatial reference can be defined for each image item in the mosaic dataset as well. If SRS field is defined both in the cameras table and the frames table, the value in frames table will take precedent.
Note:
Required*—The frames table must have either the Omega, Phi, and Kappa fields, or the Matrix field in order for the data to be added to the mosaic dataset. If both types of EO exist in the table, the transformation matrix value will be used.
Example frames table
Below is an example frames table stored as a geodatabase table, and where only a selection of the available fields are being used. Since are only four frames (images) being used in this example, there are only four rows in the table.
Example of a frames table
OBJECTIDCAMERAIDRASTERPERSPECTIVEXPERSPECTIVEYPERSPECTIVEZOMEGAPHIKAPPA
[0]
//rs/r1.jpg
512435.5404
3974985.555
958.42006
-4.485
-0.545
171.598
[0]
//rs/r2.jpg
512234.9366
3974978.869
961.96833
-0.834
-0.785
172.683
[0]
//rs/r3.jpg
512016.6162
3974971.704
969.68074
-1.177
0.994
171.427
[0]
//rs/r4.jpg
511799.7245
3974972.277
976.05905
-0.996
-1.061
171.542
