GeoFencing Sample app
999
6
09-30-2018 10:13 PM
KrishV
Occasional Contributor III
I tried using GeoFencing app which is available at arcgis-appstudio-samples/Geo-Fencing at v3.1 · Esri/arcgis-appstudio-samples · GitHub and I found that status doesn't change when I move In and Out of the fence. Is there any issue with the sample? Much appreciate your help on this.
Krish
ErwinSoekianto
Krish,
I just tested the GeoFencing sample and it is working for me, see below images. Is this only happening on certain devices?
Thank you,
Erwin
ErwinSoekianto
Krish,
Thank you,
Erwin
KrishV
Hi Erwin Soekianto‌,
Thanks for your response. I'm using App Studio Player in Iphone 7 Plus. Status doesn't change when I move inside the fence or move outside the fence.
I have uploaded the code which I have modified. Can you please let me know where I'm doing wrong.
Krish
ErwinSoekianto
My test was done on iPhone 8 (iOS 12). It's weird that it should work on yours.
KrishV
Hi Erwin,
Any suggestions how to proceed.?
Krish
ErwinSoekianto
Did you try going out of the "fence" (polygon) a little bit further out? Maybe its the GPS accuracy.
KrishV
Hi Erwin,
I replaced the service and it works perfectly!
Krish
