AnsweredAssumed Answered
Trim Function in Survey123
Question asked by buehlerd on Sep 27, 2018
Latest reply on Sep 27, 2018 by buehlerd
Is it possible to use the trim function or some other method to remove unwanted spaces due to a concatenate in Survey123?  The idea is if an field can be parsed it should be parsed from the start.  Address example 100 S Vine Ave.  100 would be in one field, S in another, and so on.  However, to run that address against a single field geocoder or even used in a form letter for a mailing (like Dear resident at 100 S Vine Ave), I need it in a single field.  When concatenated and lets say the directionality is not part of the street name (100 Vine Ave), you would get extra space so 100--Vine-Ave instead of 100-Vine-Ave
trim((${houseno_txt})+ " " + (${stdirectionnospace_txt}) + " " + (${street_txt}) + " " + (${streettype_txt})) doesn't work, and =trim((${houseno_txt})+ " " + (${stdirectionnospace_txt}) + " " + (${street_txt}) + " " + (${streettype_txt})) gives an error from a formula stand point.
Any suggestions?
Outcomes
