I publish a Python Toolbox via the admin Rest End-point on our ArcGIS Server.
When publishing a geoprocessing service there is an option to use a result map server to display the results. I have not been successful in doing this.
I use an in_memory feature class to output my data, and define my output as the following parameter:
consumption_points = arcpy.Parameter( displayName="Aftagerpunkter", name="consumption_points", datatype="DEFeatureClass", parameterType="Optional", direction="Output") consumption_points.symbology = os.path.join( os.path.dirname(__file__), 'consumption_points.lyr')
When not using the option to use a result map server, I can publish the toolbox and use the tasks in ArcGIS Pro and ArcMap. But when publishing with the option to us a result map server, i get no results back from the service.
What do I have to do to get the service published with a result map server that works? Without publishing from ArcGIS Pro/ArcMap but with using the rest endpoint on ArcGIS Server.
Robert
