AnsweredAssumed Answered
multi task script help needed
Question asked by jfritz on Sep 21, 2018
Latest reply on Sep 21, 2018 by dkwiens
Greetings,
I'm looking for someone to help write a Python script that will do the following.  (It will be important that the name of the features created in each step use the same name thru-out all the processing steps). I'm guessing using a Cursor will accomplish that.
Here's an example name:      T_0518__BVO_DJN_TP_34_5_1
1.  Buffer all the individual line features in a geodatabase by 1,250 ft (overall width of 2,500 ft.), rounded at end.
The line features are in:
c:\temp\SLR-Mapping\GIS_Projects_2018\Smart_T_Line_Model\geodata\MN_STLM_LINES.gdb
Place the resultant buffered features in following geodatabase:
c:\temp\SLR-Mapping\GIS_Projects_2018\Smart_T_Line_Model\geodata\MN_buffer.gdb
2. Clip the following raster:
c:\temp\SLR-Mapping\GIS_Projects_2018\Smart_T_Line_Model\geodata\STLM_NSP.gdb\mn_dem3second
By each of the buffered features created in Step 1Please use "Use Input Features for Clipping Geometry"
Put the resultant clipped raster features in the following geodatabase:
c:\temp\SLR-Mapping\GIS_Projects_2018\Smart_T_Line_Model\geodata\MN_CLIP_RASTER.gdb
3.  Run Raster to Point on each of the raster features created in Step 2.
Place the resultant point features in the following geodatabase:
c:\temp\SLR-Mapping\GIS_Projects_2018\Smart_T_Line_Model\geodata\MN_RASTER_TO_POINT.gdb
4.  For each of resultant point files from Step 3 the following needs to be done:
    - create "z_feet", "x_coord", and "y_coord" attribute fields
    - use the Field Calculator to populate the "z_feet" attribute from the "grid_code" attribute by multiplying by 3.2808  to get feet.
    - for the "x_coord" and "y_coord" attributes, use Calculate Geometry with the following parameters, UTM Zone 15N, NAD83, US Survey feet.
5.  LAST STEP, export the tables created in Step 4 to .csv format
Write files to the following folder:
c:\temp\SLR-Mapping\GIS_Projects_2018\Smart_T_Line_Model\geodata\MN_CSV
Many thanks in advance for help with this!!
regards,
Jim F.
Outcomes
