Hello, what is the most up-to-date imagery between the classic World Imagery and World Imagery Clarity? I guess it depends on the geographic area, but generally speaking ?
The classic imagery says is was updated in september 2018, worldwide?
The Clarity Imagery says it might be more accurate, so like the classic did it get an update?
Or even from a local point of view (say a state, a region or a town), is it possible to know when the imagery was taken? I can observe a lot of changes between these two for the same town location (i.e. North of France).
Thanks for any intel - Max
Edit:
this document lists the contributors, covered areas and year of imagery, and it looks like it has been updated early september. Plus I just read that when the clearest imagery is also the most recent one it is also provided in the classic world imagery. So problem solved I guess: classic must be the most recent in any case, while clarity might not.
cheers
though I can not give you the desired answer, here something that might at least HELP YOU for the moment to figure out when the areas you look for changed in the image basemap:
https://livingatlas.arcgis.com/wayback/
This is a great service about all image basemaps ever and the change-dates (be aware, not the image data!) at the desired locations. Check it out 🙂
Guenter
Hi Guenter, thanks for the intel, I did came across this at the end of my research last week and it is very helpful indeed.
cheers - Max
There are image services with metadata that you can query for acquisition date.
See
http://www.arcgis.com/home/item.html?id=298f03f7f02c465a87bcf817c3b8859b and
http://www.arcgis.com/home/item.html?id=c1c2090ed8594e0193194b750d0d5f83
Hi Cody, this is also very interesting and very helpful, thank you both
