Display transparent map with roads only
630
09-20-2018 07:58 AM
SapirYiflach
I've been playing around with the JavaScript SDK and I'm trying to display a map with the 'streets' basemap but I want anything but the roads to be transparent. Is this possible?
Sapir
Tags (1)
RobertScheitlin__GISP
Sapir,
   No the street map basemap is an image you can not pick and choose what you want to see.
KenBuja
MVP Esteemed Contributor
You can make alterations to the style of the vector basemaps.
Update vector tile layer style—ArcGIS Online Help | ArcGIS
The documentation links to story maps that describe how to do that
https://www.arcgis.com/apps/Cascade/index.html?appid=a74a8b251f6141fa9561041d36ea56e3
SapirYiflach
Thank you for the reply!
While this helps customize basemaps and other maps, I couldn't find a way to reference the customized map programmatically in the JavaScript API. Or did I miss something?
TIA,
Sapir
