Why won't my web layer show up as hosted?
1134
13
09-19-2018 01:46 PM
AmeliaNewsam
I've tried publishing a hosted layer from ArcGIS Pro.  It succeeds, and shows up in my AGOL content, but not as hosted layer.  What am I doing wrong?
Tags (1)
by Anonymous User
Not applicable
It appears you've shared a layer package from ArcGIS Pro to ArcGIS Online. This packages up the dataset and layer properties, enabling you to readily share it through your portal to others who want to download and unpack it.
This page covers how to share a web feature layer from ArcGIS Pro, including hosted Feature Layers.
Hope this helps,
Chris
by Anonymous User
Not applicable
How are you publishing? Can you provide a link to the service that is published?
AmeliaNewsam
I'm sharing as a hosted layer from within ArcGIS Pro.  Here's the link to the item description page on AGOL.
http://ucmerced.maps.arcgis.com/home/item.html?id=cc409fa3f8dd4b46abe3b34721f7dba3
by Anonymous User
Not applicable
The layer is not shared publicly so I can't access it via that link. If you have access to Support you may want to open a case, they will be able to screen share with you and troubleshoot the issue.
AmeliaNewsam
OK, I don't know if I do or not, but will look into it. Thanks!
AmeliaNewsam
Actually, can I just share it and then you can look at it?
by Anonymous User
Not applicable
sure, I still don't know if I will be able to figure it out or not but it's a place to start
AmeliaNewsam
OK, I just made it public.
AmeliaNewsam
One thing that may be the problem, after talking with my colleague, is that
the projection isn't correct. I didn't know that AGOL doesn't project on
the fly, so even though it allowed me to publish the layer, it won't be
openable online because of the projection problem. Does that sound likely?
by Anonymous User
Not applicable
Hope this helps,
Chris
