Conditional Formatting Example?
1909
09-18-2018 11:00 AM
MikeSnook1
Hi There,
Does anyone have a good tutorial and/or example(s) of conditional formatting that can be applied to the Dashboard Indicator widget?
Thanks!
MichaelSchoelen
Occasional Contributor III
I believe those widgets use a restricted form of HTML. There are some good examples here.
MikeSnook1
Just figured it out...I was overthinking it.  If you set a reference value (as the tutorial says) then it will present you an option/toggle for conditional formatting that has separate editors for high/low values from the reference.
