Log in Survey123 Connect
665
09-17-2018 03:46 PM
BraulioGalvez1
Hi Survey123 Team!
I have a problem with LogIn in Survey 123 connect. Today, I tried login in survey123 and don't work the application. This not give error message, just don't start the wizard for LogIn.
The video reproducing this behavior is in this link: 2018-09-17_1925
I tried reinstall "In clean" survey123 connect. I deleted all surveys allow in my laptop and reinstall, then I started survey in mode administrator, but all without success.
What can be happened? This is very important, since I have a technical track about of Survey123 in the next conference users of ESRI Chile. (03th Oct).
Note: I'm ussing the version 3.0.142
I hope your comments and thank you in advance.
Braulio.
JamesTedrick
Esri Esteemed Contributor
Hi Braulio,
Can you try to clear out your Windows Credentials as per https://community.esri.com/message/784649-re-publish-sign-in-buttons-inoperable-in-survey123-connect... - this should have been resolved but you may have been in a stuck situation from a previous install.
BraulioGalvez1
Thank you James! This could solved the issue. Now I can use survey connect! Best regards and thank you!
